Deletes a virtual link connected to another ABR.
| router_identifier | Specifies the router ID of the other end of the link. |
| area_identifier | Specifies the transit area identifier, a four-byte, dotted decimal number. |
N/A.
Router-identifier—Far-end router identifier, a four-byte, dotted decimal number.
Area-identifier—Transit area used for connecting the two end-points. The transit area cannot have the area identifier 0.0.0.0. and cannot be a stub area or an NSSA.
The following command deletes a virtual link with router ID 10.1.2.1 through the transit area 10.1.0.0:
configure ospfv3 delete virtual-link 10.1.2.1 10.1.0.0
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
